TwinTurbo.NET: Nissan 300ZX forum - Re: Use the "search" function above to learn about these thi
Subject Re: Use the "search" function above to learn about these thi
Posted by SR707DRIFT on December 23, 2009 at 11:54 AM
  This message has been viewed 83 times.
In Reply To Use the "search" function above to learn about these things. posted by zellamay on December 22, 2009 at 01:39 PM
Message Ok thank you. My engine has quote and quote 45k miles because it was
bought from a shop and installed by them. It isn't a jdm motor it's a
usdm motor. I've done searching but I just wanted to get others
opinions. Another thing that wasn't added is that when I got the car it
had old gas in it and it ran to the gas light when I bought it which makes
me believe it clogged the injectors. And the oil is original oil from the day
the motor was swapped in. So right after I bought it I put new gas in it
as well as fuel injector cleaner. And then did an oil change. After the oil
change I noticed it was running better and the idle stayed at close to a
grand. But then after about 2 minutes of idling it started being jumpy.
I'm going to check the ohm's on the injectors either today or tomorrow
to make sure there good.
